กระทู้: __ เป็น ดีเจรถซิ่ง ง่ายๆด้วย มือถือ/ipad +สาย Griffin DJ Cable สำหรับแอพ DJay
    Jul 2009
    Thumbs up __ เป็น ดีเจรถซิ่ง ง่ายๆด้วย มือถือ/ipad +สาย Griffin DJ Cable สำหรับแอพ DJay
    สาย Griffin DJ Cable for iphone ipad ipod สำหรับแยกเสียงหูฟังกับลำโพง ในการใช้แอพ djay
    https://griffin.zendesk.com/hc/en-us...DJcable_ts.pdf
    The Griffin Technology DJ Cable is designed to be used with iOS mobile devices and enables the Split Output function when using the djay algoriddim app. With Split Output mode enabled, djay sends the master output to the left channel, and the cue output to the right channel. This lets you cue songs through your headphones independently of the mix that's going through the speakers. The cable has connectors for the speaker system, headphones and audio jack for your device.
    For iOS mobile devices - enables Split Output when using djay app
    Splitter cable allows you to hear the speaker mix and the song being cued up
    Connectors for speaker system, headphones and audio jack on your iOS device
    Pre-Cueing
    Previewing with headphones
    The ability to pre-cue, or preview, the next track through your headphones is essential for any DJ to seamlessly mix the currently playing track into the next track. This allows for finding the perfect next track, flawless beatmatching, and creating a mix customized for your crowd.
    In djay, there are two ways you can pre-cue your tracks: by using the Split Output function paired with a stereo/mono DJ split cable, or by connecting an external sound card or DJ controller.
    A proper DJ split cable lets you cue up the next track in your headphones independently from what the crowd is currently hearing from the speakers, allowing for a smooth mix.
    DJ split cables can be enabled through djay?s Split Output function for pre-cueing. Optimal features you want to look for are gold-plated connectors for improved conductivity and better signal, as well as a durable exterior for longevity.
    Note: A DJ split cable splits your stereo jack into two mono channels. This means your speaker output using this setup will always be mono (using two duplicate mono output channels).
    รายละเอียดสินค้า
    อุปกรณ์เสริมสำหรับ ipad, iphone, ipod touch เพื่อใช้เชื่อมกับโปรแกรม DJ สามารถแยกเสียงหูฟังกับลำโพงได้ ของมือ1 เก่าเก็บ
    950 ฿ ลดเหลือ 750 รวมส่ง ems/kerry
    สนใจโทร 0869455977
    หรือ Line ID: ctek.thai
    ถ้าไม่เห็นรูปรบกวนกดไปดูที่ลิ้งนี้นะครับ
    http://www.hamsiam.com/smf/index.php?topic=254318.0
    Jul 2009
    Thumbs up ตอบ: __ เป็น ดีเจรถซิ่ง ง่ายๆด้วย มือถือ/ipad +สาย Griffin DJ Cable สำหรับแอพ DJay
    ขาย อุปกรณ์รวมเน็ต 2 เส้น CISCO RV042G กิ๊กกะบิท Load Balance ราคาถูก
    ขาย Cisco RV042G Gigabit Load balance router สามารถทำ VPN, Load balance ได้
    มี 4 พอร์ท 10/100/1000 (Gigabit) 1 พอร์ท Internet 1 พอร์ท DMZ/Internet (Gigabit)
    สรุปรวมมี 2 พอร์ท (Gigabit) ที่จะให้ Internet เข้าได้และ 4 พอร์ท (Gigabit) สำหรับเครือข่าย.
    ประกัน LifeTime
    สามารถทำ Firewall ได้, ทำ VPN, Load balance, กำหนดความเร็วภายในเครือข่ายได้, ฯลฯ รายละเอียดเพิ่มเติมโปรดดูได้จากเว็บไซต์ของ Cisco โดยตรง.
    คุณสมบัติของสินค้า
    - Cisco RV042G เป็นอุปกรณ์ VPN / Load Balanced Router รองรับการทำงาน VPN 50 Tunnels
    - รองรับ Load Balance 2 Gigabit WAN เชื่อมต่อ internet ได้ 2 สาย
    - บล็อก/จำกัดการใช้งานเว็บไซด์ที่ไม่ต้องการได้
    - จำกัดความเร็วในการใช้งาน ในระดับผู้ใช้และ Protocol ได้
    - รองรับ VPN Pass-through แบบ PPTP, L2TP, TPsec
    - รองรับ Firewall แบบ SPI, denial of service (DoS), ping of death, SYN flood, land attack, IP spoofing, email alert for hacker attack
    - รองรับ Port forwarding, Port triggering
    - มี LAN แบบ 100/1000Mbps จำนวน 4 ช่อง
    - ขนาด 130 x 38 x 200 มม.
    Cisco rv042g Datasheet : http://www.cisco.com/c/en/us/product...c78-706724.pdf
    ประกัน LifeTime / ประกัน : advice ตลอดอายุการใช้งาน
    ราคา 3900 บาท พร้อมส่ง flash ฟรีทั่วไทย
    ราคาร้อนเงิน 3500฿ พร้อมส่ง ภายใน 10/10/64
    สิ่งที่มีให้:
    ตัวเราเตอร์ (router) ของ Cisco RV042G
    อแดปเตอร์เสียบไฟบ้าน
    ราคาของใหม่ประกันแค่1ปี 7xxx บาท
    ของเรา ประกัน : advice ตลอดอายุการใช้งาน
    ขาย 3900 บาท พร้อมส่ง ems/flash ฟรีทั่วไทย
    #โทรสอบถามที่ 0869455977
    line : ctek.thai
    Jul 2009
    ขาย บูสเตอร์ และ Power supply Motorola 13.8V 50Amp Base Micor repeater
    รายการที่ 1
    Motorola Micor Repeater power supply TPN1105A TLN5300A ex police radio network
    เฉพาะ Power supply Motorola 13.8V 50Amp ถอดมาจาก Motorola MICOR Repeater (ตามรูปที่วงสีแดงๆ)
    ไม่ว่า syntor , spectra , maratrac , power amplifier ขนาด 300w ก็สามารถใช้งานได้ไม่มีสัญญาณ noise หรือ hum รบกวนเครื่องวิทยุสื่อสาร
    สภาพเหล็กตัวเครื่องเงาๆสวยๆ ซื้อมา หมื่นกว่า ขายราคา 7500 บาท พร้อมส่ง (นน.เยอะมากๆ)
    รายการที่ 2
    Motorola TLD1692D 100W Continuous Duty RF PA
    เฉพาะ power amplifier ของ Base Micor repeater มาพูดง่ายๆคือบูสของ motorola base station เป็นของมือสองสภาพใหม่ๆ ( ตามรูป )
    เอามาใช้งานได้ทันทีกับไฟ 13.8v ป้อน rf input 400mW - 1W ออก 100w - 125w ย่าน 144 mhz ย่าน 16 ประมาณ 70W
    วัดกับ BIRD43 ไม่มีร้อน
    ซื้อมาตัวละสองหมื่นกว่า ขายราคา 8500 บาท พร้อมส่ง (นน.เยอะ)
    เหมาทั้งสองรายการคิด 15000 จากปกติ 16000 ประหยัดไปอีก 1000
    สนใจโทร 0869455977
    http://www.hamsiam.com/smf/index.php?topic=254200.0
    Jul 2009
    IntAct Battery Guard อุปกรณ์ตรวจสอบแบตเตอรี่รถ ด้วยสมาร์ทโฟน จากเยอรมัน
    - ตรวจสอบVoltขอแบตเตอรี่ด้วยสมาร์ทโฟนผ่านระบบบลูทูธ
    - ติดตามสถานะแบตเตอรี่ของคุณได้ตลอดเวลา
    - สามารถใช้ได้กับยานพาหนะทุกประเภท
    - ติดตั้งง่ายเพียงต่อเข้ากับแบตเตอรี่(ขั้ว+ และขั้ว-)
    - สามารถตรวจสอบแบตเตอรี่
    ขนาด 6V. 12V. และ 24V. ได้
    - ใช้พลังงานเพียง 6-24 มิลลิวัตต์
    - มีระบบป้องกันการต่อขั้วย้อนกลับ ไม่ก่อให้เกิดความเสียหาย
    กับเครื่องส่งสัญญาณหรือแบตเตอรี่
    - สามารถใช้งานร่วมกับ iOS, Android
    หรือ Windows 10
    - แอพพลิเคชั่นสามารถรองรับ Battery-Guard
    ได้มากถึง 10 ตัว
    - ตรวจสอบระดับการชาร์จและประวัติย้อนหลังของvoltในแบตเตอรี่ของคุณ
    ผ่านบลูทูธในสมาร์ทโฟน
    #intAct #batteryguard #intactbatteryguard
    #intactbatterythailand #อุปกรณ์วัดแบตอัจฉริยะ
    ตรวจสอบแบตเตอรี่รถ จากโทรศัพท์มือถือ เช็คแบตใด้ตลอดเวลาที่คุณต้องการด้วย intact Battery-Guard
    Intact Battery-Guard - Smart Battery Health Monitor
    ตรวจสอบแบตเตอรี่ผ่านสมาร์ทโฟนด้วย intAct Battery-Guard คุณจะสามารถเฝ้าดูระดับแบตเตอรี่ของคุณได้อยู่เสมอ ไม่ต้องรื้อถังไม่ต้องเอามิเตอร์ไปต่อขั้วแบตให้ยุ่งยากอีกต่อไป
    อุปกรณ์เสริม ที่สามารถตรวจสอบแบตเตอรี่ได้จากโทรศัพท์มือถือ Smartphone ใด้ตลอดเวลาที่คุณต้องการ ทั้งจากมือถือระบบ ios / Android และ windows10 ด้วยแอพฟรีจาก Intact Battery-Guard
    วิธีง่ายที่สุดในการเช็คสภาพแบตเตอรี่ ใช้ในการตรวจสอบแบตเตอรี่ทั้งแบบ 6V / 12V / และ 24V ของยานพาหนะทุกชนิด
    ใช้กับแบตเตอรี่ตะกั่ว-กรด ได้ทุกรุ่น รวมทั้งแบต แห้ง, น้ำ, Gel , Lithium และ AGM
    Intact Battery-Guard นำเข้าและผลิตจากประเทศ เยอรมัน ทนทานกันฝุ่นและน้ำ รับประกันคุณภาพ1ปีเต็ม
    - รับประกัน 1 ปี
    - Made in Germany
    - แอพพลิเคชั่นฟรีทั้งสำหรับ ios / Android และ windows10
    ราคาปกติ 2490 ฿
    ลดราคาพิเศษล็อตเปิดตัวเหลือเพียง 1,350 บาท พร้อมส่ง ems ฟรีทั่วไทย
    Battery monitoring with the smartphone - with the intAct Battery-Guard you always keep an eye on your battery.
    With the intAct Battery-Guard and the free Apple or Android app, you are now able to check the charge status of your battery quickly and easily, because only in a steady, positive battery state of charge, the full capacity and usability is ensured. The positive battery charge condition also prevents possible early damage or a failure of the battery. After the easy installation to the battery by ring eyelets and after downloading of the Android or Apple app, the current voltage value can be retrieved. The transmitter is suitable for 6 V, 12 V and 24 V batteries. The range is about 6 meters. The four-colour, tachometer-like display shows the state of charge in dark green (fully charged), light green (partially charged), orange (unloaded) and red (fully discharged). In addition, the voltage value is represented alphanumerically. When dropping below the minimum voltage a reference will be made to recharge the battery as soon as possible.
    By using the app, the voltage of up to 5 batteries can be monitored, obviously an intAct Battery-Guard has to be installed at each battery.
    ?Up to 5 vehicles can be monitored
    ?Monitoring of 6, 12 and 24 volts possible
    ?Easy installation by ring eyelets to the battery
    ?Power consumption is only about 2 mW
    ?No damage to the transmitter or the battery if polarity is reversed
    ?Free Download of the App "intAct Battery-Guard" in the App Store or the Google Play Store
    รีวิวการใช้งาน วีดีโอสาธิตการทำงาน Intact Battery-Guard
    https://youtu.be/RKwOUHs_qy8
    https://youtu.be/uXtP6hRjg7g
    https://youtu.be/8uuJGEL9LSo
    https://youtu.be/8X08iX1gD_U
    https://youtu.be/h9gcwDQwcMQ
    ราคาปกติ 2490 ฿
    สนใจสินค้าโทร. 0869455977
    หรือ Line ID : CTEK.THAI
    ถ้าไม่เห็นรูปรบกวนกดไปดูที่ลิ้งนี้ครับ
    มีหลายรายการ คลิ้กไปดูรายละเอียดทุกชิ้นใด้ที่
    http://www.hamsiam.com/smf/index.php?topic=254173.0
    Jul 2009
    ถูกที่สุดในไทย MikroTik Cloud Router Switch CRS125-24G-1S-2HnD-IN ของใหม่
    -เป็นทั้ง Router และ Switch Layer 3และยังสามารถทำเป็น AP กระจายสัญญาณ Wireless ได้อีกด้วย
    -เหมาะสำหรับระบบเครือข่ายขนาดกลาง
    -รองรับการทำงานอย่างเช่น Load Balance, Cache, Log, หรือเก็บ Auto Script ต่างๆ
    อุปกรณ์ Cloud Router Switch รุ่น CRS125-24G-1S-2HnD-IN เป็นทั้งไวเลสเร้าเตอร์และสวิตซ์ในตัว
    มี 24 พอร์ต 10/100/1000 Ethernet และ 1 พอร์ต SFP ฟังก์ชั่นสวิตซ์บริหารจัดการได้ระดับ L3
    ระบบปฎิบัติการ MikroTik Router OS Level5 license รองรับการทำ Load Balancing / Gateway / Firewall / VPN
    ปล่อยไวไฟย่าน 2.4GHz มาตรฐาน 802.11b/g/n มี 2 เสาอากาศขนาด 4 dBi กำลังส่ง 20dBm (100mW) ใช้ CPU AR934, RAM 128 MB
    เหมาะสำหรับเครือข่ายขนาดย่อมถึงขนาดกลาง
    คู่มือการติดตั้ง และปรับแต่งอุปกรณ์ MikroTik RouterBOARD
    http://www.sys2u.online/XPERT_FORUM2_MikroTik.html
    ซื้อมาจะทำโปรเจ็ค แล้วไม่ใด้ทำ
    ของใหม่ อุปกรณ์ครบชุดยกกล่อง ไม่เคยใช้งาน ตามรูป
    ซื้อใหม่ตอนนี้เค้าขายกันอยู่ 8,850 บาท
    https://www.sys2u.online/P20170422-1...etal-Case.html
    เราขายเพียง 5,950 บาท รับประกัน1ปี พร้อมส่ง ems/kerry ฟรีทั่วไทย
    ราคาร้อนเงิน 5550 ems+ 50 บาท ภายใน 10/07/64
    สนใจโทร 0869455977
    https://forums.chiangraifocus.com/in...opic=1163367.0
    Jul 2009
    ลดราคา 500 การ์ดแลน เซิฟเวอร์ Intel PRO 1000PT Dual Port / HP NC360T ราคาเบาๆ
    NEW HP NC360T PCI Express Dual Port Gigabit Server Adapter ประกัน 1 ปีเต็ม
    สำหรับลูกค้าที่ต้องการหลีกเลี่ยง สินค้าลอกเลียนแบบ หรือของปลอม*
    Standard Features
    Performance 10/100/1000 Mbps
    PCI Express Interface
    Load Balancing
    Jumbo Frames
    Reliability
    Dual Port
    Network Fault Tolerance
    Distance Capabilitie
    Network Management
    Auto-Negotiation
    Wake-on-LAN
    Management Support (SNMP)
    Server integration
    Configuration Utilities
    LED indicators
    วันนี้มี Intel PRO 1000PT Dual Port/HP NC360T ราคาเบาๆ มาขายครับ
    สินค้าใหม่ ซื้อมากะไว้สำรอง พอดีเปลี่ยน Server แล้วมันเป็น Quad Port เลยไม่ได้ใช้แล้วครับ
    ความสเถียร และ Performance ดีกว่า Card แบบปกติหลายขุมครับ ประกัน 1 ปีเต็ม
    ซื้อมา 3500 ขายขาดทุน 2500 รวมส่ง EMS/kerry ครับ
    ราคาร้อนเงินลดเหลือ 1999 ems+ 50 บาท ภายใน 10/07/64
    สนใจโทร 0869455977
    ถ้าไม่เห็นรูปรบกวนกดไปดูที่ลิ้งค์นี้นะครับ
    http://www.hamsiam.com/smf/index.php?topic=254216.0
    Jul 2009
    เครื่องชาร์จแบตเตอร์รี่อัจฉริยะ NOCO GENIUS10 10 A. (10000mA) ใหม่ล่าสุด!!
    ปรับฟังก์ชันเพิ่มมากขึ้นด้วยการเพิ่มโหมดสำหรับชาร์จแบตเตอรี่ lithium / โปรแกรมในการชาร์จ (Can-Bus) และโหมดช่วยฟื้นฟูแบตเตอรี่จากการเกิดการเกาะตัวของผลึกซัลเฟตบริเวณแผ่นธาตุ,
    โหมดอากาศหนาวเย็น และระบบการดูแลที่ช่วยถนอมและคืนสภาพให้กับแบตเตอรี่ NOCO GENIUS10 สามารถรองรับได้ทั้งแบตเตอรี่ขนาดใหญ่และขนาดเล็ สำหรับใช้แบตเตอร์รี่ 6V และ 12V
    ชาร์จแบตเตอรี่ตั้งใด้สูงสุด 230แอมป์ (สามารถชาร์จรถยนต์ได้) มีโหมดโปรแกรมที่สามารถฟื้นฟูแบตเตอรี่ เพื่ออายุการใช้งานได้
    ความเร็วในการชาร์จ ชั่วโมงละ 10 แอมป์ อุปกรณ์ครบ สายแบบปากคีบและตาไก่ในตัวเดียวกัน 1 ชุด
    ราคา 8900 บาท
    จัดส่ง ems ฟรีทั่วประเทศ
    รายละเอียดทั้งหมดดูใด้ที่ http://bit.ly/1vlpE41
    สนใจติดต่อ 0869455977
    ID Line CTEK.THAI
    ตารางแสดงรายละเอียดเครื่องชาร์จแบตเตอรี่ Noco Genius G7200 / NOCO GENIUS10 สำหรับรถจักรยานยนต์ และรถยนต์ รุ่นต่าง ๆ
    เครื่อง ชาร์จ+ฟื้นฟู +จ่ายไฟ+จั๊มสตาร์ท แบตเตอรี่ แห้ง/น้ำ มอเตอร์ไซค์ รถยนต์ เรือ ยานพาหนะทุกชนิด อัจฉริยะ NOCO GENIUS จาก อเมริกา ถูกที่สุด/ดีที่สุด ประกันสูงสุด5ปี
    สินค้าที่เรามีจำหน่าย ซื้อสินค้า 1500฿ขึ้นไป ส่ง ems ฟรีทุกชิ้นครับ
    เครื่อง ชาร์จ+ฟื้นฟู +จ่ายไฟ+จั๊มสตาร์ท แบตเตอรี่ แห้ง/น้ำ มอเตอร์ไซค์ รถยนต์ รถบรรทุก เรือ ยานพาหนะทุกชนิด อัจฉริยะ NOCO GENIUS จาก อเมริกา ถูกที่สุด/ดีที่สุด รับประกันสูงสุด5ปี
    รถคุณไม่ค่อยใด้ขับ/จอดมากกว่าใช้งานรึปล่าว เวลาจะ ขับ/ใช้ แบตหมดใช่มั้ย ถ้าใช่ลองคลิ๊กดูครับ มีของดีสำหรับรถที่จอดมากกว่าใช้
    รถคุณจอดมากกว่าขับรึปล่าว จอดนานจน แบตหมด/สตาร์ทไม่ติดใช่มั้ย ถ้าใช่สิ่งนี้ช่วยแก้ปัญหาแบตให้คุณใด้ ลองคลิ๊กดูก่อนครับ ดีแน่นอน
    คลิ้กไปดูที่ลิ้งค์ข้างล่างเลยครับ สินค้ามีทุกรุ่นพร้อมส่ง ems ทั่วไทยครับ
    สินค้าที่เรามีจำหน่ายนะครับ รายละเอียดทั้งหมดดูใด้ที่ http://bit.ly/1vlpE41
    เครื่องชาร์จแบตเตอรี่อัจฉริยะ NOCO GENIUS จาก USA ดีที่สุด/ถูกที่สุด รับประกันสูงสุด5ปี
    NOCO GENIUS รุ่น GENIUS5/GENIUS10/G15000/G26000 V.2 ใหม่ล่าสุด!!
    ใช้งานง่ายชาร์จโดยไม่ต้องยกแบตเตอรี่ออกจากรถ ไม่ต้องถอดขั้วแบต เต็มแล้วตัดไฟอัตโนมัติ ไฟตกชาร์จต่อเอง รถไม่ใด้ใช้งานเสียบทิ้งใว้ใด้เป็นปีๆ
    เหมาะสำหรับรถที่จอดทิ้งไว้ไม่ได้ขับ(จอดมากกว่าใช้) หมดปัญหารถสตาร์ทไม่ติด และแบตเสื่อมเร็วจากการทิ้งให้ แบตอ่อน/หรือหมดไฟ อยู่เรื่อยๆ
    ใช้ได้ทั้งรถยนต์และมอเตอร์ไซค์ และยานพาหนะทุกชนิด มีระบบฟื้นฟูและกระตุ้นแบตเตอรี่ ช่วยให้แบตเต็มอยู่ตลอดเวลา ซึ่งเป็นการยืดอายุการใช้งานแบตเตอรี่ใด้ยาวนาน
    NOCO GENIUS V.2 เป็นรุ่นใหม่ล่าสุด!!! ปรับฟังก์ชันเพิ่มมากขึ้นด้วยการเพิ่มโหมดสำหรับชาร์จแบตเตอรี่ lithium / โปรแกรมในการชาร์จ (Can-Bus) และโหมดช่วยฟื้นฟูแบตเตอรี่จากการเกิดการเกาะตัวของผลึกซัลเฟตบริเวณแผ่นธาตุ, โหมดอากาศหนาวเย็น และระบบการดูแลที่ช่วยถนอม กระตุ้น ฟื้นฟูแบตและคืนสภาพให้กับแบตเตอรี่
    และโหมด Jump Charge ใด้ด้วย ในรุ่น G15000/G26000
    สเปคเครื่องชาร์จ NOCO GENIUS จากอเมริกา รับประกันสูงสุด5ปี
    - GENIUS 5 สามารถชาร์จแบต 6/12 โวลต์ ขนาดเล็กและใหญ่ ได้สูงสุดถึง120 ah ราคา 5250฿ 3 year waranty
    - GENIUS 10 สามารถชาร์จแบต 6/12 โวลต์ ขนาดเล็กและใหญ่ ได้สูงสุดถึง230 ah ราคา 8900฿ 3 year waranty
    - G15000 สามารถชาร์จแบต 12โวลต์ ได้ตั้งแต่ 30 - 400 ah / แบต 24 โวลต์ ได้ตั้งแต่ 14 - 200 ah ราคา 13,600฿ 5 year waranty
    - G26000 สามารถชาร์จแบต 12โวลต์ ได้ตั้งแต่ 50 - 500 ah / แบต 24 โวลต์ ได้ตั้งแต่ 25 - 250 ah ราคา 16,900฿ 5 year waranty
    (G26000/G15000 มีโหมด Supply สำหรับฟื้นฟูแบตเตอรี่ที่มีแรงดันไฟฟ้าต่ำ และโหมด Jump Charge ใด้ด้วย)
    สายวัดกำลังไฟ+เสียบชารจ์+แสดงสถานะด้วย led
    - GC015 GENIUS EYELET Indicator 12V 50 cm. 750 ฿
    - GC016 Dashmount Battery Indicator 12V 1.5 m. 1,250 ฿
    - GC011 แจ๊คสำหรับเสียบชาร์จกับระบบ canbus สำหรับรถ BMW หรือ เสียบชาร์จกับที่จุดบุหรี่ สำหรับรถทั่วไป 950 ฿
    - GC009 แจ๊ค SAE สำหรับเสียบชาร์จกับรถ HARLEY DAVIDSON หรือ รถอื่นๆที่ใช้แจ๊ค SAE 590 ฿
    เครื่องทดสอบและวิเคราะห์สภาพแบตเตอรี่แบบดิจิตอล DHC BT111/BT222 มีคู่มือไทย
    - DHC BT111 Battery Analyzer เครื่องตรวจสอบและวิเคราะห์สภาพแบตเตอรี่ 2950฿ 1 year warranty
    - DHC BT222 Battery Analyzer 3in1 เครื่องวิเคราะห์สภาพแบตเตอรี่ 12V / ทดสอบ ระบบการชาร์จ (ไดร์ชาร์จ) / วิเคราะห์ระบบขณะสตาร์ท (ไดร์สตาร์ท) ใด้ด้วย 3in1 3750฿ 1 year warranty
    รีวิวการใช้งาน วีดีโอสาธิตการทำงาน BT222 https://www.youtube.com/watch?v=J5xLVwua0X8
    https://www.youtube.com/watch?v=6glRNWsZ9nM
    - Intact Battery-Guard - Smart Battery Health Monitor อุปกรณ์สำหรับตรวจสอบแบตเตอรี่ได้จากโทรศัพท์มือถือ
    อุปกรณ์เสริม ที่สามารถตรวจสอบแบตเตอรี่ได้จากโทรศัพท์มือถือ Smartphone ใด้ตลอดเวลาที่คุณต้องการ ตรวจสอบแบตเตอรี่ทั้งแบบ 6V / 12V / และ 24V ของยานพาหนะทุกชนิด
    ลดราคาพิเศษเหลือเพียง 1,950 บาท พร้อมส่ง ems ฟรีทั่วไทย
    ซื้อสินค้า 1500฿ ขึ้นไปพร้อมส่ง ems ฟรีทั่วไทย
    - สนใจรุ่นใหนโทร 0869455977
    หรือ Line ID : CTEK.THAI หรือ NOCOTHAI
    หรือคลิ๊ก http://line.me/ti/p/~CTEK.THAI
    รายละเอียดเครื่องชาร์จ/จั๊มพ์สตาร์ททั้งหมดดูใด้ที่ http://bit.ly/1vlpE41
    - NOCO GENIUS GENIUS 5 เหมาะที่สุดกับการชาร์จแบตมอเตอร์ไซค์ และชาร์จ BigBike SuperBike ใช้ชาร์จแบตรถยนต์ใด้ แต่ชาร์จแบตรถยนต์ค่อนข้างช้า ถ้าไม่ซีเรียสเรื่องเวลา และแบตรถยนต์ไม่เกิน 120 แอมป์ GENIUS 5 ก็ใช้ใด้ครับ
    - NOCO GENIUS GENIUS 10 เหมาะที่สุดกับการชาร์จแบตมอเตอร์ไซค์ และชาร์จ BigBike SuperBike และแบตรถยนต์ ขนาดไม่เกิน 230 แอมป์ ชาร์จแบตใด้เร็วกว่ารุ่น GENIUS 5 1เท่า
    - NOCO Genius G26000 ดีที่สุด 26A (26000mA) Pro-Series UltraSafe Smart Battery Charger with JumpCharge
    สำหรับชาร์จแบตเตอรี่ 12V และ 24V เครื่องชาร์จสำหรับใช้งานกับแบตเตอรี่ขนาดใหญ่ ตั้งแต่ 25 แอมป์ขึ้นไป - 500Ah เช่น รถยนต์, เรือ, รถบรรทุก, รถ RV และรถแทรกเตอร์
    G26000 ชาร์จแบตใด้เร็วกว่ารุ่น GENIUS 5 6เท่า เช่นถ้ารุ่น G5 ชารจเต็มที่6ชม รุ่นG26000 ก็จะชารจเต็มที่ 1 ชม.
    (เครื่องจะชาร์จให้จนเต็มแล้วตัด หลังจากนั้นจะมอนิเตอร์แรงดันไป ถ้าตกลงต่ำกว่า90% จะทริกชาร์จให้จนเต็มแล้วตัดแล้วมอนิเตอร์อีกแบบนี้ไปเรื่อยๆซึ่งทำให้แบตเต็มอยู่ตลอดเวลา)
    มาพร้อมฟังก์ชันการทำงานพิเศษสำหรับรักษาแบตเตอรี่จากภาวะการเกิดผลึกซัลเฟต, โหมด Supply สำหรับฟื้นฟูแบตเตอรี่ที่มีแรงดันไฟฟ้าต่ำ และโหมด Jump Charge ใด้ด้วย
    ถ้าคุณเลือก เครื่องชาร์จ / เครื่องจั๊มพ์สตาร์ท ไม่ถูก เรามีคำแนะนำในการเลือกเครื่องชาร์จให้ตรงกับความต้องการ จากฟังค์ชั่นการใช้งาน และความเร็วในการชาร์จ ลองอ่านดูครับ
    - ถ้าไม่เกี่ยงเรื่องงบและต้องการ ชาร์จทั้งแบตเตอรี่ 12V และ 24V แนะนำรุ่นใหญ่สุด noco G26000 ครับ สะดวกสุด ชาร์จเร็วสุดเร็วกว่ารุ่นเล็กสุด8เท่า จั๊มสตารทใด้ภายใน5นาที 16900฿
    - ถ้าต้องการให้ถูกกว่านั้น อาจใช้เครื่องชาร์จ noco G15000 ชาร์จใด้ทั้งแบตเตอรี่ 12V และ 24V ชาร์จเร็วกว่ารุ่นเล็กสุด4เท่า จั๊มสตารทใด้ภายใน5นาที 13600฿
    - หรือถ้าไม่ต้องการ จั๊มสตาร์ท และชาร์จไม่ช้ามากก็ใช้ noco GENIUS 10 เร็วกว่ารุ่นเล็กสุด1เท่า 8900฿
    - ถ้าไม่ต้องการฟังค์ชั่น จั๊มสตาร์ทและโหมดจ่ายไฟ และไม่ซีเรียสความช้าในการชาร์จรถยนต์ก็ตัวเล็กสุด noco GENIUS 5 5250฿
    *** สนใจรุ่นใหนโอนแล้วแจ้งใด้เลยครับ สินค้าพร้อมส่ง ems ทั่วไทยครับ ***
    Jul 2009
    ตตตตตตตตตตตตตตตตตตตตตตตตตตตตตตตตตตตตต
    Jul 2009
    NOCO Genius G26000 ดีที่สุด มาแล้ว..!!! ตัวเลือกที่คุ้มค่า คุ้มราคา..สำหรับท่านที่ต้องการชาร์จทั้งแบตขนาด 12 และ 24 โวลต์ ในตัวเดียวกัน สามารถจั๊มพ์สตาร์ทใด้ด้วยครับ
    สำหรับชาร์จแบตเตอรี่ 12V และ 24V เครื่องชาร์จสำหรับใช้งานกับแบตเตอรี่ขนาดใหญ่ ตั้งแต่ 50-500Ah เช่น รถยนต์, เรือ, รถบรรทุก, รถ RV และรถแทรกเตอร์
    G26000 ชาร์จแบตใด้เร็วกว่ารุ่น g3500 7เท่า เช่นถ้ารุ่น G35 ชารจเต็มที่7ชม รุ่นG26000 ก็จะชารจเต็มที่ 1 ชม.
    - G26000 สามารถชาร์จแบต 12โวลต์ ได้ตั้งแต่ 50 - 500 ah / แบต 24 โวลต์ ได้ตั้งแต่ 25 - 250 ah 16,xxx฿
    เครื่องชาร์จสำหรับใช้งานกับแบตเตอรี่ขนาดใหญ่ เช่น รถยนต์, เรือ, รถบรรทุก, รถ RV และรถแทรกเตอร์
    NOCO G26000 ปรับฟังก์ชันเพิ่มมากขึ้นด้วยการเพิ่มโหมดสำหรับชาร์จแบตเตอรี่ lithium / โปรแกรมในการชาร์จ (Can-Bus) และโหมดช่วยฟื้นฟูแบตเตอรี่จากการเกิดการเกาะตัวของผลึกซัลเฟตบริเวณแผ่นธาตุ
    โหมดอากาศหนาวเย็น และระบบการดูแลที่ช่วยถนอม ฟื้นฟูแบตและคืนสภาพให้กับแบตเตอรี่
    G26000 มาพร้อมฟังก์ชันการทำงานพิเศษสำหรับรักษาแบตเตอรี่จากภาวะการเกิดผลึกซัลเฟต, โหมด Supply สำหรับฟื้นฟูแบตเตอรี่ที่มีแรงดันไฟฟ้าต่ำ และโหมด Jump Charge ใช้จั๊มสตาร์ทใด้ด้วย
    NOCO GENIUS ใช้ได้ทั้งกับแบตเตอรี่แห้งและแบตเตอรี่น้ำ Wet, Gel, MF, CA, EFB, AGM and LIB ทุกยี่ห้อ ขนาด ตั้งแต่ 50-500Ah รวมทั้งแบตเตอรี่ Gel ( Gel Battery or GelCell ) และ AGM ( AGM Battery )
    สนใจสินค้าโทร 0869455977
    Jul 2009
    ขาย การ์ดแลน เซิฟเวอร์ Intel PRO 1000PT Dual Port / HP NC360T ราคาเบาๆ
    Standard Features
    Load Balancing
    Jumbo Frames
    Reliability
    Dual Port
    Network Management
    Auto-Negotiation
    Wake-on-LAN
    Server integration
    LED indicators
    ราคาร้อนเงิน 1950 + ems 50 ภายใน 30/08/64
    สนใจโทร 0869455977
    Jul 2009
    ดีงามมมมมมมมมมมมมมมมมมมมมมม
    Jul 2009
    สุดยอดดดดดดดดดดดดดดดดดดดดดดดดดดดดดดดดดดดดดด
    Jul 2009
    ดันวันดี
    Jul 2009
    very goooodddddddddddd
    Jul 2009
    very goooddddddddddddddd
    Jul 2009
    สอบถามใด้ครับบบบบบบบบบบบบบบบบบบบบบบบบ
  1. Lenso จัดหนัก แรงส์ แจก IPAD MINI
    โพสโดย pang ในฟอรั่ม ห้องพักผ่อน
    ตอบกลับ: 2
    โพสล่าสุด: 25-11-2013, 21:43
  2. ใครอยากได้ iPad mini เชิญทางนี้
    โพสโดย krookeng ในฟอรั่ม คำแนะนำสำหรับผู้ซื้อรถไทรทันใหม่
    ตอบกลับ: 9
    โพสล่าสุด: 11-06-2013, 19:44
  3. ตอบกลับ: 0
    โพสล่าสุด: 22-05-2013, 00:22
  4. Starter Kit Ipad in Car
    โพสโดย RedCool ในฟอรั่ม เครื่องเสียงรถยนต์
    ตอบกลับ: 2
    โพสล่าสุด: 02-02-2012, 08:42
